msterbeau
msterbeau New Reader
5/3/20 9:05 a.m.
How does one adjust the stop correctly?
I would put the car up on jack stands, get it close to where I think it should be and then use an assistant outside the car telling me when the drive wheels start turning (Obviously the car is running) to dial it in. Something like that?  Is there an easier way?
wspohn
wspohn Dork
5/3/20 10:56 a.m.
Park on a slight hill in first gear with engine off. Put a block a couple of inches behind the back tire or in front of you are nose down (and a handy assistant as a failsafe if you like).
Install the stop in the car. Push down the clutch pedal. Keep adjusting the stop inward until the car rolls against the block when you push the pedal in.  Done.
Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
5/3/20 10:45 p.m.
Most cars have unsynchronized reverse so it's pretty easy to tell the clutch engagement point in most cars by just holding the shifter in a specific spot where reverse is not engaged but the gears are touching. When the clutch starts to engage you'll feel it through the shifter as the moving gear starts to clash against the stationary one.
weedburner
weedburner Reader
5/4/20 11:13 a.m.
David S. Wallens said:
Click on either graph to open in a new window.
From the top, the data cells show speed on track, throttle pedal position, engine speed, and total time gained/lost. The lower chart is just a zoomed-in version of the top one. “The zoom better shows the resolution of the throttle trace and rpm spike in that shift,” Clay explains.
“Before the first shift on the back straight–third to fourth–both drivers are approximately the same speed,” he explains. “After the first shift, the blue driver is 2 mph faster than the red immediately.”
Clay dives deeper into the data: “In this shift, red comes off throttle at 1:19.766, back on at 1:20.269–almost exactly 0.5 seconds. Blue comes off throttle at 1:19.928, back on at 1:20.269–about 0.3 seconds.”
“Note that clutch pressure would be an interesting data point also,” he continues, “and the blue driver shows the negative effects of shifting too fast: trying to jam all the actions of the sequence in.
“The ‘shift tail’ in the rpm graph shows that the driver overlapped pedals–a big no-no. The clutch pedal was already going down before the throttle pedal was fully released, although you can see in the graph that it was more of an issue of inertia than late throttle release.
“Nevertheless, this is one of the ways that shifting fast can damage the engine, clutch, or driveline–although adjustment of a proper clutch stop does make this much easier to time.
“Over the duration of the full back straight, and with no other factors in these runs, faster shifting and the increased terminal mph achieved has made the blue driver, who came onto the straight slower, a total of 0.3 seconds faster in this straight alone.
“Add the front straight and the shorter middle straight and you just put at least half a second in your pocket through proper equipment adjustment and perfecting technique.”
The most telling thing I see in graphs is the engine rpm traces. It's obvious that the quicker driver made more power thru the shift, evidence of that is in the rpm flare. The engine's rotating assy absorbed energy during the shift which is what caused the flare, then the car was able to transfer that added flare energy to the track without spinning the tires. The result was more power applied to the track over the same time period. Pedal stop adjustment may have had a hand in changing the driver's timing to create the flare, but harnessing that rpm flare without breaking traction is what made him faster.
I actually have clutch pressure data on my car, and also have a way to adjust the rate that the clutch actually engages. The main benefit of being able to adjust clutch engagement rate is the ability to reduce the intensity of energy transfer between the rotating assy and chassis, to a level that doesn't cause the tires to break traction. Most customers are using my ClutchTamer and Hitmaster clutch control devices in a drag racing setting, but some road and rally guys are also using them as more efficient alternatives to the Tilton Flow Control Valve
Grant
msterbeau
5/6/20 2:21 p.m.
In reply to wspohn :
Nice.  Thanks.
slowbird
slowbird SuperDork
1/21/21 9:59 p.m.
Pretty sure my Focus needs some adjusting because there's no way I could shift that fast. Of course it has no clutch feel and I have no skill either, so that compounds the problem. blush
1tKg9xCxLiEHPGBzhJXU4YtWZ9J0lmACh1kaxf6l0Of7smiavB5GgXP5P5eTRgPy
