Login to post Forums » Grassroots Motorsports » Graphics Removal - Challenge Related
  • Moparman
    May 15, 2011 10:32 a.m. Moparman HalfDork
    We are having great difficulty getting the old fading, cracking graphics from our Challenge Shelby Dakota.I have used heat. bug and tar remover and Oops and nothing will dissolve the glue. Any ideas?
  • Woody
    May 15, 2011 10:49 a.m. Woody SuperDork
    I have very carefully removed graphics from motorcycle gas tanks with razor blades, without damaging the paint. It's not easy and it takes a long time.
    Or you could try one of these:
    http://www.eastwood.com/vinyl-eraser-and-arbor.html
  • Moparman
    May 15, 2011 11:12 a.m. Moparman HalfDork
    Coming along, but slowly. I will probably have it done by the time this arrived from Eastwood.
  • Tom Suddard
    May 15, 2011 11:13 a.m. Tom Suddard SonDork
    We use those vinyl eraser things at the body shop, it's by far the safest and quickest way to remove graphics.
  • AquaHusky
    May 15, 2011 11:43 a.m. AquaHusky Reader
    When my dad worked for GM a long while ago, when the Firebirds had the screaming chicken hood emblems, he used to use a razor to peel off the ones that had bubbles or not on straight.
  • JThw8
    May 15, 2011 1:20 p.m. JThw8 SuperDork
    WD40 actually helps soften up the glue
  • donalson
    May 15, 2011 2:25 p.m. donalson SuperDork
    could use one of those plastic razor blades... less of a chance of getting the paint...
    but ya i've read enough times that those big erasers are the way to go...
  • Karl La Follette
    May 15, 2011 2:35 p.m. Karl La Follette Dork
    chiCrud Defeaterzler and heat gun
  • Moparman
    May 15, 2011 2:52 p.m. Moparman HalfDork
    Truck is about 1/3 stripped now.
  • Moparman
    June 5, 2011 2:54 p.m. Moparman HalfDork
    I guess I am going ti try the graphic eraser. We have about 40% of the graphics removed but the rest just won't come. I have tried heat, 3m chemicals, razor blades, etc. None work very well. The 3m stuff doesn't affect the glue at all, not even the glue left on the truck after the graphics are off.
  • Junkyard_Dog
    June 5, 2011 3:30 p.m. Junkyard_Dog Dork
    You can get that eraser at a NAPA or body supply place for about $20. You'll never use anything else after you've tried it.
  • former520
    June 5, 2011 10:53 p.m. former520 New Reader
    I picked up an old rabbit racecar that had decade old near full wrap in it. I tried everything and ended up with the eraser. Now I never even bother to try anything else.
