I'm reading the GT-6 restoration article (CMS March 2010) and I'm trying to figure out how the Allen screws on the rear A-arms (p 102) allowed the adjustments alluded to in the article.
Did they push against the bolt and give a couple degrees of camber or toe? Or is it locking an eccentric? I'm fairly mechanically competent but this has me puzzled. Which most likely is the object of the exercise.
By comparison, I can see how the adjuster on the rear leaf spring works...
