Huckleberry
Huckleberry MegaDork
5/13/17 9:43 a.m.
buzzboy wrote: It's probably similar to how you turn traction control off 1) warm up the engine fully. 2) turn off the engine. 3) the side brake needs to be released. 4) press and hold the brake and start the engine. 5) while holding the brake, pull the side brake and let go of the brake. 6) press the brake 2 or more times and hold the brake. 7) while holding the brake, release and pull the side brake 2 or more times and hold the side brake. 8) while holding the side brake, press the brake 2 times. 9) TC and VSC lights should turn on.
Seriously? I've seen that control scheme before...
Knurled
5/13/17 9:49 a.m.
I thought you had to shift to 1st, 2nd, 1st, Neutral. Then turn the steering wheel to the left and right twice. Then apply the brake, accelerator, clutch, and starter in sequence.
Wiki article
zVQa6RvvSyK23pqdh2VcNOzwWJrDf06UUHlRrOl7jd5raY9DH4jvW64QcNFbQavZ
