Login to post Forums » Grassroots Motorsports » Help me with a 9-5
  • belteshazzar
    May 18, 2010 11:33 a.m. belteshazzar SuperDork
    I've got this 2000 SAAB on my car lot. It is a 4 cylinder turbo with a 5sp. There is only one code stored in the ecu according to my cheap scan tool. P0502 Vehicle speed sensor A, low input. Where is that, what should I do? Other symptoms include inop speedo/odo, warning light that TCS is off, warning light for ABS system.
    Thanks fellas.
  • 81gtv6
    May 18, 2010 11:54 a.m. 81gtv6 HalfDork
    I bet it is the computer for the ABS. I had the same thing happen to my 9-3, I guess the solder joints get weak and crack causing exactly what you are describing.
    The part is the plastic thing on the front of the ABS pump. I got one off of a 900 in the junkyard but you can get them rebuilt here:
    http://www.bba-reman.com
    or here:
    http://cheap-abs.com/
    Should not be more than $150 and the car is driveable without the module.
  • belteshazzar
    May 18, 2010 1:49 p.m. belteshazzar SuperDork
    you're a handy devil.
    anyone else?
