Coming home from my mom's yesterday, I dropped into 3rd to get around a slow moving minivan merging onto the highway, shortly after I got a check engine light in the Abarth. Torque says it was P1CEA and a Google search found this on a forum:
"There is a new Tech Bulletin out for 2013 Abarths with the P1CEA code. This time it is a reflash that fixes the light. Read below:
2013 Fiat 500 Abarth TSB 18-028-13
SUBJECT: Flash: MIL Illumination P1CEA- Boost Side Evap Purge System Performance
OVERVIEW: This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
MODELS: 2013 (FF) Fiat 500/Abarth (Hatchback only)
NOTE: This bulletin applies to vehicles equipped with a 1.4L engine (sales code EAF) built on or before February 14, 2013 (MDH 0214XX).
SYMPTOM/CONDITION: A small number of customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the Technician may find that the following Diagnostic Trouble Code has been set: · P1CEA- Boost Side Evap Purge System Performance
Updating the PCM software will correct the condition listed above. "
But checking under the hood to see if I popped a fitting or something simple I noticed this fitting seemed loose. I pulled it off for a better photo:
It plugs into the black fitting directly below it. I thought I remembered unclipping it to remove from the stock unit & put into the new CAI. But the tab was bent slightly and I couldn't make it unclip, and no amount of force got it to stay on the black fitting. I have a Tuesday appointment for the CEL, is this related or something of a bonus problem?
