John Brown (Forum Supporter)
John Brown (Forum Supporter) GRM+ Memberand MegaDork
7/22/20 3:27 p.m.
So I just read that Holley has released a version of the Terminator X engine control that is compatible with Direct Injection.
Linky here
So if DI on a GM with VVT can be unlocked, how long before other DI engines could see this?
Saron81
Saron81 HalfDork
7/22/20 3:33 p.m.
Syvecs and other top end standalones can already do Fords with DI and VCT.
alfadriver (Forum Supporter)
alfadriver (Forum Supporter) MegaDork
7/22/20 3:33 p.m.
In reply to John Brown (Forum Supporter) :
I would not call it unlocked, but someone went through the trouble of understanding how to control the DI hardware.  Which is so much different than PFI that it's pretty hard.  Given the plug and play nature of what they are trying to do, they seemed to have also downloaded the important parts of the MAP that would be almost imposisible to develop w/o a dyno and months of working on it.  That also explains why they are so specific with the controllers.
But it just took time and money to do it.
bobzilla
bobzilla MegaDork
7/22/20 3:59 p.m.
Pipe dream.... but someone do it for the 1.6T from the Korean twins. I am just imagining a 200+whp 1.6 in a lot of older Korean cars that weighed very little.
7/22/20 6:14 p.m.
There exists already an aftermarket computer out of the UK that can control 4 cylinder Ecoboosts.  I forgot the name,  but they mainly seem to focus on the 1.6.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) Dork
7/22/20 7:01 p.m.
Probably Life Racing (same hardware as Syvecs)
7/22/20 8:25 p.m.
But does it scratch records to Chuck D's satisfaction?
Carbon (Forum Supporter)
Carbon (Forum Supporter) UltraDork
7/22/20 9:50 p.m.
I bet a homebrew Di Ls turbo is quite a thing.
7/22/20 9:59 p.m.
https://www.scs-delta.co.uk/ford-ecoboost-ecu
7/23/20 6:07 a.m.
The good news is that the hardware set available for DI is fairly limited- once you choose a hardware set, all of it stays with that company.
The bad news is that even wiht that, you will need a pretty specific side set of hardware to make it run.  And, based on what i'm seeing, all of them could be traced to a hacked OEM ecu, so that the very diffucult mapping of the engine (much of the DI and VCT development) is already done.
On what's available- I do find it interesting that it appears that Ford systems were out first, when GM has so many hacked ECU's in the US.  But it is what it is, and it now opens up the availabiliy of swaps that OEM's decided not to support.  A field day for this community.
qlF4Pb8OBlgeu9TOsrLNZWQk8NG5v25fms8WuI4NJ5Sk6ng5CpEaLACDOg1zUvMt
