Login to post Forums » Grassroots Motorsports » how much power from a 13b?
  • Derick Freese
    Oct. 1, 2011 11:09 p.m. Derick Freese Dork
    I'm posting this here due to the signal/noise ratio on the appropriate forums.
    The question is pretty simple. How much power can be made with a naturally aspirated 13b? The plan is to use Mega Squirt for engine controls. I don't want to lose drivability, because I have plans with the engine that include a heavier vehicle than an RX7.
  • Mazdax605
    Oct. 1, 2011 11:11 p.m. Mazdax605 Dork
    4-port,or 6-port? Any plans for porting?
  • Derick Freese
    Oct. 1, 2011 11:19 p.m. Derick Freese Dork
    Maybe a street port, but the motors that are more available to me are 6 port motors.
  • Greg Voth
    Oct. 1, 2011 11:26 p.m. Greg Voth HalfDork
    You are probably looking at roughly 150 rwhp without a streetport. Up to 200 rwhp with a streetport but that would be pushing it.
    I had a mild streetported 6 port 13B with 3rd gen rotor housings, RX-8 rotors, running off megasquirt. It made 160 rwhp (dyna-pak which reported reads a little lower). It had an S4 intake and the 5th and 6th ports removed.
    If I were to do it over I would keep the ports and run a S5 intake. Also avoid running an aluminum flywheel and race clutch. It kills street ability with the little torque available.
  • Derick Freese
    Oct. 1, 2011 11:33 p.m. Derick Freese Dork
    Yeah, I'd be running a stock flywheel, but a heavier clutch.
    I don't want to give anything away, but this would be mounted mid-ship.
  • Derick Freese
    Oct. 1, 2011 11:43 p.m. Derick Freese Dork
    What about porting the S4 intake? Is the S5 just cast in a better shape and the S4 isn't worth the trouble?
  • mr2peak
    Oct. 2, 2011 1:46 a.m. mr2peak Reader
    2nd gen MR2?
  • Osterkraut
    Oct. 2, 2011 3:20 a.m. Osterkraut SuperDork
    My street-ported 13B put down 193hp to the wheels. Want to buy it? It's sitting in my parent's shed a little south of Ocala.
  • Derick Freese
    Oct. 2, 2011 7:41 a.m. Derick Freese Dork
    Osterkraut, that might be a possiblility. I have to check to see if it will work for the application with that long RX7 transmission.
  • Osterkraut
    Oct. 2, 2011 9:55 a.m. Osterkraut SuperDork
    Don't forget you can mix and match transmission sections to build a really short one! Ask Josh about it.
  • Derick Freese
    Oct. 2, 2011 10:53 a.m. Derick Freese Dork
    A shortened transmission just might do. Do you want to be clued in on the emails we're sending back and forth?
  • Oct. 3, 2011 11:49 a.m. Knurled Dork
    The S4 intake has been proven time and again to make more power than the S5 unit.
    But don't let this info get around, I like snapping up S4 intakes for cheap-to-free.
  • Osterkraut
    Oct. 3, 2011 12:32 p.m. Osterkraut SuperDork
    No, that'll only get me hankering for a good project. I'll cut you a deal on that 13B if you decide you want it (it won't be cheap, as it's a solid, low mile rebuilt long block, but it'll be a deal).
