On the Saturn i have been brainstorming and have come up with a dilemma, i would like your input/ ideas. Thank you JTHW8 for your help thus far
If the Saturn gets lowered and i put some stuff in it or people i just know the rear is gonna sag. Stock springs will sag a bit in the rear with people in the back.
My solution was to add a helper air bag on each side in the rear. Trucks do so so help when they carry a load so why not i. Or is there an air strut i could put the spring onto and bump up air pressure when i have a load? Should a adapt a air shock from a factory car/truck? If this is the case then maybe make it so when they are deflated its in the normal range of suspension movement then inflated it would help provide lift?
Some might tell me "then dont lower it" and that is a valid comment HOWEVER this is not a lower it/ dont lower it thread. I would like to have the best of both worlds.
I have inclosed some pictures if that helps.
The bar in the middle is the sway bar so that hurts mounting a air bag a bit harder...
Lastly, some saturns had no rear sway bar so i guess i could remove it and run with out a rear bar. (still have front sway bar)
