Login to post Forums » Grassroots Motorsports » IACV fix?
  • CivicSiRacer
    April 29, 2009 12:56 p.m. CivicSiRacer Reader
    Don't know if you guys have a Grassroots way of fixing this before I have to shell out money.
    I have a 93 Civic Si with 230,000 miles. Last week had the head gasket replaced. Afterwards took the car out for a drive and the car was bogging and almost stalled a couple times.
    Took it back to Honda and they tried to fix the timing and found the ICV (Idle Control Valve) is sticking open and shut. New part is $200 including labor. They say if that is replaced my idling and bogging should go away.
    Does anyone know a fix for this? I'm skeptical about buying one off Ebay, and some friends recommend buying new. I just spent $$$ on head gasket and new clutch and wife wants to kill me if I put anymore money in
    Right now it will idle high (1200-1400 rpms) when warm, turn AC on it will drop to well below 500rpms. Sometimes it will idle normally around 700rpms. Around 2000-3000 rpms will be a slight bog and then accelerate again.
    I cleaned it with Carb cleaner year ago or so.
  • internetautomart
    April 29, 2009 1:17 p.m. internetautomart SuperDork
    on some cars you can clean the IAC with some carb cleaner.
    My suggestion is to disassemble it and clean it thoroughly then reassemble and reseal it.
  • April 29, 2009 1:33 p.m. Nashco SuperDork
    As said, they can usually be cleaned to free them up. Give it a shot again, it might only buy you another 6-12 months, but if you're trying to avoid buying a new one that's the tradeoff. Meanwhile, go to the junkyard and get another used one for $10. Clean it and when it starts acting up again, it's a ten minute job to swap it out and you can clean the other one when you get around to it.
    Cheap, fast, and easy. Pick two.
    Bryce
  • Grtechguy
    April 29, 2009 2:17 p.m. Grtechguy UltraDork
    soak it in seafoam over night
