Login to post Forums » Grassroots Motorsports » I'm jonesing e24...
  • stroker
    July 7, 2011 3:40 p.m. stroker HalfDork
    on a whim I checked CL for e24's in CA and found a ton of nice looking ones for what I thought was cheap. I'd really like a nice one at some point....
    I keep telling myself that a sedan for two adults and two small kids would be a nice car for long trips (although the mpg on them sorta sucks) but I think that's why we bought our minivan...
    Somebody please tell me that they fall apart after 120,000 miles or that the spark plugs cost $10,000 to change or that the big end bearings tend to explode with no warning.
    Just out of curiosity though, if you had a nice roller available what current BMW 6 would you put into one?
  • BoxheadTim
    July 7, 2011 3:52 p.m. BoxheadTim SuperDork
    Errr, e24 is the landshark, not a sedan...
    Anyway, the main issue with e24s and other BMWs of that vintage is rust, followed by "the CA sun killed the interior" on the e24s. I was considering a couple of e24s that were cheap earlier this year and pretty much all of them had a interior that needed a lot of work if you wanted it to become nice again.
    Mechanically, they're about as robust as they come, but manual 633s and 635s are hard to come by.
  • RossD
    July 7, 2011 3:56 p.m. RossD SuperDork
    http://appleton.craigslist.org/cto/2471725380.html
  • Travis_K
    July 7, 2011 4:46 p.m. Travis_K SuperDork
    The only really bad thing I noticed when looking at them is most of them have had zero maintenance for quite some time, and the owners really have no idea of the history. I ended up not buying one because I couldn't find one that was going to be drivable without a lot of work.
  • bravenrace
    July 7, 2011 4:49 p.m. bravenrace SuperDork
    In reply to stroker:
    Can you guys ever use the name of the vehicle? I have no idea what a e24 is.
  • mad_machine
    July 7, 2011 5:07 p.m. mad_machine SuperDork
    the original 6 series. The pretty one from the late seventies up to almost 1990, not the monstrosity on the road today
    Nice virtual M6:
  • oldtin
    July 7, 2011 5:16 p.m. oldtin Dork
    check mye28.com, there's usually a few e24s around on the classifieds. Found my e28 there.
    No need for a newer engine - m30s are tough - many around with 300k+ - add boosts.
    for bravenrace - late 70s to late 80s bmw 6 series
  • Hasbro
    July 7, 2011 5:23 p.m. Hasbro Dork
    Here is how it works.
    BMW started back in the late '60s and early '70s denoting their bodies with an E and then a number. They also have denoted their motors by an M and then a number, or in special cases an S and then a number. Here is how the E works
    E3 - Bavarias, the 4 door sedan that BMW made in the late '60s and early '70s.
    E9 - Coupes as in the 2800cs and the 3.0cs made in the late '60s and early '70s.
    E12 - The First 5 Series. Make from late '70s to early '80s.
    E21 - First 3 Series. In the US the 320i. In the rest of the world, 320i, and 323i.
    E23 - First 7 series.
    E24 - The 6 series, all of them. Unfortunately here is a confusing point. BMW called the 6 series by the same E name even though in 1982 they completely changed the suspension and many other things. When talking about 6 series you also need to talk about year.
    E28 - The Second Generation 5 Series. Make from '82 to '87.
    E30 - Second Generation 3 Series. Built from '83 to 90. Convertables continued to Dec. '92.
    E31 - 8 series
    E32 - Second Generation 7 series.
    E34 - Third Generation 5 series. This car was built from '89 through '95.
    E36 - Third Generation 3 series. Came in such things as the 318ti, and the Z3 verions.
    E38 - Third Gen. 7
    E39 - Fourth Gen. 5
    E46 - Fourth Gen. 3
    As for the motors BMW started with the original 4 cylider and has gone from there.
    M10 - Four cylinder found in 2002 and 320i
    M30 - Big Six, based on M10 but with 2 extra cylinders. Found in every large BMW(not 3 series) up to and including the E34.
    M20 - Baby Six, smaller displacement 6 cylinder.
    M40 - Four cylinder first found in the E30 318is. This is the motor with the profile gasket problem.
    M50 - Multi-valve small six that replaced the M20.
    M52 - All Aluminum small six that replaced the M50.
    M motors go by a different designation. They use S. S14 - E30 M3 motor based on M10.
    S38 - E28/E34/E24 M5/M6 motor based on the M30.
    Written by Rob Anderson '00
  • iceracer
    July 7, 2011 5:26 p.m. iceracer SuperDork
    agree 100%
  • mad_machine
    July 7, 2011 5:33 p.m. mad_machine SuperDork
    you sure the M40 was the engine with the profile gasket problem? I thought it was the M42?
    the M40 should be a sohc engine.. the M42 and M44 were DOHV 16v
