Login to post Forums » Grassroots Motorsports » Installing Brake control
  • Nov. 8, 2009 5:33 p.m. blaster None
    I am in a bind. I have a camper at Grand Isle, La and hurricane Ida is bearing down hard right now. I have already installed the rails and hitch but was going to have the brake controller installed tomorrow. The problem is I can't wait until tomorrow. They are calling for evacuations now and I need to go get my camper.
    I am not a mechanic but I can do most things if told how in simple terms. I was hoping someone out there could walk me through the installation of the controller in my 2003 f-250. It already has the hook up on the rear, factory installed. I'm hoping there is a simple way to do this without having to tear into the wiring. I see 4 wires coming out of the harness as it goes into the engine compartment that are the same color wires as is on the controller. Could I be lucky enough for that to be for the controller pre wired from the factory? Can someone please help?
  • xci_ed6
    Nov. 8, 2009 5:54 p.m. xci_ed6 Reader
    Check this out: http://www.youtube.com/watch?v=ee8_UUFfK68
  • cwh
    Nov. 8, 2009 5:59 p.m. cwh SuperDork
    Good luck, storms can be a real bitch. I would go get it even if the good stuff was not hooked up yet. I've been through too many hurricanes. Do not hesitate, GO!!!
  • Nov. 8, 2009 7:42 p.m. blaster New Reader
    Thank you very much for the link. I don't have the adapter but at least I know what wires to splice to. That did the trick. Again, thanks. By the way, I hate hurricanes! I'll be leaving shortly headed that way.
  • 44Dwarf
    Nov. 8, 2009 8:31 p.m. 44Dwarf HalfDork
    It should be wired from the factory BUT...likely will not have the two relays under the hood. www.fordtrucks.com will help ya.
    44
