Login to post Forums » Grassroots Motorsports » J-H race car progress so far
  • Jensenman
    Nov. 15, 2008 5:06 p.m. Jensenman SuperDork
    I've been working on the J-H project for a while now, thought I'd post my progress.
    The front suspension was pretty time consuming. The original setup had no camber adjustment provision so I had to modify the upper control arms. Here's the front suspension about halfway figured out. The outer tie rod end is Miata, I only had to run a 1/2-20 tap to clean up the threads and they spun right onto the J-H inner tie rods. This fixed the original bump steer quite nicely.
    <img src="Photobucket" alt="" />
    Here's the front suspension assembled and ready to install. The shocks are QA1 coilvers with 550 inch pound springs.
    The stock J-H rear axle has no aftermarket. So I decided to narrow a RX7 GSL rear axle; 3:89 gearing,limited slip and disc brakes. The stock J-H axle is 54" drum to drum, the RX7 piece is 57 3/16". So I had to narrow the rear axle. It was a crappy rainy day today so I got busy disassembling the rear axle and cutting off all the stock RX7 bracketry.
    Here's the RX7 housing after all the brackets were stripped, the bearing carriers were removed and the housing was narrowed. I have to build a jig so I can keep everything straight when I burn it all together. I got the inspiration for this part of the project from this Web page: http://the-mite.com/mite22.htm Many thanks to aeronca 65t for pointing me to that site!
    I have to send the axle shafts to Dutchman Motorsports to be cut and resplined, I will also have them redrill for the Miata 4x100 mm bolt circle.
    Next up: convert the RX7 bellhousingfrom hydraulic to cable clutch. This will involve moving the pivot to the opposite side of the bellhousing. Should be fun.
  • billy3esq
    Nov. 15, 2008 8:01 p.m. billy3esq Dork
    Looks like fun, but I've got a question. What does the sticker on the back of the driver's seat say? All I can make out is "Danger--Driver is...."
  • Jensenman
    Nov. 15, 2008 8:38 p.m. Jensenman SuperDork
    'Insane'.
    I'm disappointed. As a lawyer, you should never ask a question you don't already know the answer to, and I would think that one was pretty obvious.
  • billy3esq
    Nov. 18, 2008 10:36 a.m. billy3esq Dork
    I just had to do it. There were a number of things I could've filled that blank in with.
    Yes, I did just end a sentence with not one, but two prepositions. I'm quite the rule-breaker this week.
  • DILYSI Dave
    Nov. 18, 2008 10:41 a.m. DILYSI Dave SuperDork
    I'm pretty sure two prepositions make it OK, kinda like a double negative or a reverse cowgirl.
  • Dr. Hess
    Nov. 18, 2008 4:02 p.m. Dr. Hess SuperDork
    Looks nice, JM.
    But, do we really KNOW that billy3 didn't already know the answer to the question? He could have known, but was merely trying one of his secret lawyer tricks on us. You know, like "how often do you beat your wife?" Any further reply from him regarding this would also have to be discounted as merely more lawyer lying, or whatever they call it.
  • billy3esq
    Nov. 18, 2008 6:38 p.m. billy3esq Dork
    Advocacy--the word you're looking for is advocacy.
