OK here's the situation. My parents went away for a weeks vaca......uh...hmm. Sidetracked already.
So I finally relocated the radiator on the fiat to the front of the car. I ended up running 1" EMT conduit to the front of the car. To get the water there and back.
So After all this work I am left with 2 issues. The first is the volume of coolant is just too large. It takes almost 45 minutes on a 90 degree day for the engine temp to stabilize at 180F. The second is less ground clearance even though I tried my best to tuck it up as high as possible. It scrapes over speedbumps and on the gravel pulling into my driveway.
So after thinking about it I am beginning to feel that the diameter is overkill. The hole in the thermostat that all the water going to the radiator through is maybe 1/2" at the most when fully open. That transitions to a 1 inch hose that runs 6 or 7 feet to the radiator and then another one that runs all the way to the back of the car and enters the suction side of the Meziere electric water pump which is.....you guessed it, just over 1/2".
Now I just happen to have a 20 foot spool of 5/8" ID stainless steel braided teflon tubing laying around. Why wouldn't this be a perfectly fine and sensible solution?
