so i picked up a 94 elantra that I can't seem to flip.
As usual that causes my mind to think motor swaps and top chops.
If I'm reading the webz right, I can swap in the 4g63 directly with little more than using the donor ecu.
edumacate me on the possibilities of this beater
June 5, 2011 10:51 a.m. internetautomart SuperDork
June 5, 2011 11:46 a.m. mad_machine SuperDork
I think you can only use the later 4g63s as the early ones are backwards...
the Beta is not a bad engine.. it can be boosted.. and the parts are out there to do it
June 5, 2011 2:23 p.m. impulsive New Reader
up to 95 the Elantra is still 1G Mitsu based, motor is on drivers side1.8 = 4G67
http://www.roadraceengineering.com/mitsumotorapplications.htm
June 6, 2011 11:38 a.m. Bobzilla Dork
Correct, first gen Elantra's are little more than differently shaped miustu's. 4G63 is a direct swap.
