miataman86
miataman86 Reader
9/5/12 1:44 a.m.
I'm wanting to know about adjusting the cam plates that adjust the camber and caster of a Miata. I want to know which side is the + side and which is the - side. Also, how do the increments go as far as degrees wise? There are notches on them and how exactly are those calibrated?
Keith Tanner MegaDork
9/5/12 10:04 a.m.
If you move the lower control arm out, you'll get more negative camber.
The increments are not actually calibrated. I believe they're just handy marks. If they were calibrated, they wouldn't be evenly spaced.
miataman86
miataman86 Reader
9/6/12 8:31 a.m.
How do I move the lower control arms?
9/6/12 9:45 a.m.
By turning the alignment cams. The correct direction of rotation will depend on which side of the car you're working on and/or if the cams are installed upside down or not.
codrus
codrus Reader
9/6/12 1:44 p.m.
If you take the cam bolts out and play with them, then it's fairly obvious how things work. (note that doing this will screw up the alignment -- theoretically you could mark it and put it back in the same spot, but I've never had much luck with doing that).
miataman86
miataman86 Reader
9/10/12 6:42 p.m.
Which side said of said alignment cams are the negative side? I know one is positive and one the other is neagtive.
SNSlzwov0Wz9y9190i9ii6qmWhvN7pol
