I'm looking to make the ol Rally Pumpkin less "pumpkinish". I would like to break up the orange with something. Also need some advice on the paint. It is shiny in some areas and not in others. Wet sanding? If so, what grit?
As to the paint issues, do you know what type of paint is on it? Single stage or base clear?
Wet sand and polish is pretty aggressive. You need to make sure you have enough paint so that you don't burn through. But a good cut and buff job does miracles.
Yeah, I'd second the idea for adding some black. That's a lot of orange. Some black should add some depth and contrast.
I'm going to recommend a nice 50% grey, slightly warm, instead of black. Black and orange is fine, but a bit strong and a bit overplayed.
JohnRW1621 wrote: Sample of a Cuda-like stripe on a Civic
Kind of Signal Auto-ish
and strangely enough they have several orange cars over the years
Nick (picaso) Comstock wrote: As to the paint issues, do you know what type of paint is on it? Single stage or base clear? Wet sand and polish is pretty aggressive. You need to make sure you have enough paint so that you don't burn through. But a good cut and buff job does miracles.
I have no idea and no paint. It was done by the previous owner.
Sounds like buffing would be a better idea.
Zooming in and seeing your tires I am reminded that you use this for Rallyx. This means you are in fields and trees.
Maybe fashion a "cone hunter" theme with the use of camo vinyl.
Boss or Cuda stripe done in camo. For more wild, I'd like to see tiger stripes done on camo and then fashion a toy gun "gun rack" in the rear window.
I think it would look great as a Jack-O-Lantern. Paint the "face" parts in black. Halloween is right around the corner!
JohnRW1621 wrote: If you think you need to increase the car's visibility, some variation on this...
This makes me think about a possible Lemons theme...
