So, after everything, I've got some mad understeer going on in the Mustang ('90 5.0 'vert).
I love the torque arm, but it's go so much grip it's just overpowering the front end at this point. I'm not really sure what I can do to improve front end bite without dropping traction out back.
Up front I'm running SN95 spindles and MM CC plates, but I'm still maxing out for negative camber at under a degree (no, my plates aren't backwards). I probably need to replace the A-arm bushings (150k on the car and I think it still has the stock bushings/balljoints), but I don't really want to rip the A-arms out, as that just turns into a justification snowball where I end up ripping out the whole K-member and dropping in an Agent47 SLA.
I remember someone on here (Sorry, not good with names, but your avatar is a white SN95 Cobra) saying that foxbodies counterintuitively benefit from a larger swaybar up front when encountering understeer.
So, thoughts? Should I start just by replacing the bushings and balljoints and throw a camber bolt in my strut mount?
Is swapping to a tubular k-member and coil-overs the night/day difference up front that the torque-arm was out back?
Or do I just suck it up and save my pennies for a front end worth three times what the car is?
