GameboyRMH MegaDork
3/4/17 5:13 p.m.
In TunerStudio while the engine is running I can see the AFR on a gauge labeled "Air:Fuel Ratio 1" and in my SD Card Datalogging setup, I have the fields AFR, AFR 1 Target, and AFR 1 Error selected, among others. But when I look at the logs, I see sensible values for AFR 1 Target and AFR 1 Error (considering what's coming next), but "AFR" is pretty much a flatline around 0.3. Any ideas what I'm doing wrong?
BTW this is an MS3X with a Spartan Lambda 2
Paul_VR6
Paul_VR6 Dork
3/4/17 8:41 p.m.
Can you host and link the log?
GameboyRMH MegaDork
3/5/17 6:09 a.m.
GameboyRMH MegaDork
3/6/17 7:46 a.m.
Bump for the work week.
MadScientistMatt
MadScientistMatt PowerDork
3/6/17 10:02 a.m.
If you have just upgraded the firmware, try removing AFR from the SD card list and re-adding it.
GameboyRMH MegaDork
3/6/17 10:09 a.m.
Haven't done a firmware upgrade since the car was first set up, but I'll try that.
GameboyRMH MegaDork
3/6/17 9:22 p.m.
Removing and re-adding the AFR field (and writing the settings to the MS3 in between) fixed it, thanks Matt!
E1N0R5LOBOIVIIki1f1PcPBZhRX5Y8Aadx2hFsv00eEoowVPPUYaoQbspwXr9OQY
