We are hurriedly wrapping up our Challenge build and have some install questions on the MS and the WBO2 sensor.
Our current setup is this MS: http://www.miataturbo.net/showthread.php?t=13676
We have a NAW WBO2 sensor with premade controller and harness that terminates with two separate grounds, a switched 12v and a 0-5v O2 sensor output. Taiden was kind enough to assemble it for me.
The main question is does the 0-5v output connect to the MS in the same location as the factory (narrowband) O2 sensor? We think it is pin 23 on the MS, which is a pink wire.
Two other small questions:
Is it important to separate the locations of the 2 grounds?
- What is a good under dash source of a switched 12v?
Thanks!
