I get spark and fuel out of my MS, but the car won't start.
I'm unsure if I have the spark input/output correct. The car has a VR sensor in the distributor with 4 "blades" and is firing a single coil. The injectors are 143cc.
Can anyone see anything glaring obvious (I'm oblivious)j with the below:
Engine Constants Required fuel - 15.0 Speed Density Injections per cycle - 4 Injector Staging - Alternating Four Stroke Cylinders - 4 Port injection Injectors - 4 Even Fire
Injector Characteristics Injector Open Time - 1.1ms Battery Voltage Correction .08v PWM Current Limit - 55 PWM Time Threshold 1.0 Imjector PWM period - 66 Bank2 Specific Bank 2 settings - No
Tach input settings Basic Trigger 60.00 Trigger Angle GM options - Off Ignition Input Capture - Falling Edge Spark output Going high Spark output - D14
