Hi, I have the tranny out of my '90 Miata to replace the slipping clutch. The inside of the bellhousing is covered in what smells like engine oil (not tranny, although I'm might replace the front tranny seal anyway), but I'm not sure if it's the seal or the half moon of the oil pan that's leaking (the CAS area is clean and dry).
Am I right in assuming that the seal seals oil that is under pressure while the half moon is not pressurized (by the oil pump)? And so it's more likely to be the culprit?
The seal I took out looked fine, but I don't think they have to look bad to leak.
Anyway, hate to take the pan off, even with the tranny out (although I'm not sure if that makes it any easier) so wondering if there is anyway I can figure out where the leak is coming from. Hate to put the new clutch in and have it slip as well. Any suggestions?
Thanks very much!
