Replacing the engine in my '95 miata, did the dumb thing and didnt label/ take pictures along the way. I have 2 wires which I cant remember where they go.
Help is greatly appreciated.
1st picture is a ground, stick it anywhere. (Maybe valve cover?)
2nd one i'm not sure about, but looks like the same connector mazda likes to use for coolant temp sensors.
thats what i suspected on the first one.. the second one.. I am pretty sure it was routed over to the drivers side like that, but dont see where it goes..
It's the type of connector that goes over a metal "spade," right? Does it have to do with EGT? I have a similar connector on the manifold/heatshield of my MSM. (But up by the firewall.)
Its round on the inside, not a spade.. only one connection and the connector is female. There isnt a connection on the exhaust other then the O2 sensor which that is not.
Maybe i meant EGR.
Bummer on o2 sensor. That was going to be my next guess lol.
Where are the temp and oil pressure senders, and do they have a wire on them yet?
Oil pressure is hooked up, (under intake)
not sure where the temp sensor is located.. gonna dig out my enthuast manual and try to figure out where it is/ if that goes there
not coolant temp, thats on the back of the head (and connected)
The round one is the power steering pump wire. The left one i believe is a ground. It goes to the bolt that is right above your hand in the picture that holds the intake in place, between the intake and the timing cover. There is a rusty bolt on the timing cover. Go directly left and there is a bolt that is partly hidden by a wire bundle. I think that is where it goes (at least on a 1.6L).
Yup, PS pump wire.
THANKS!
enthuast manual confirms it.. I looked at that and didnt think it was a connector, but they have a pic of it in the power steering section hooked up.
IT LIVES!!!!!!!!!!!!!
http://www.youtube.com/watch?v=lWyb99cA-nM
(need to hook up one alternator wire and finish bolting on the exhaust)
