Login to post Forums » Grassroots Motorsports » Miata track day suspension
  • ppddppdd
    June 22, 2011 9:31 a.m. ppddppdd Reader
    I'd ask this on miata.net, but...meh. I assume Keith can help with a lot of this.
    I'm getting my replacement Miata ready to do a few track days. Most of my play money went toward covering the gap between the insurance settlement on the old miata and the new one. I've got a bunch of parts left over from my wrecked '90, though!
    Suspension-wise I've got the following:
    Assembled Koni sports, stock '90 springs, some progressive bump stops off of a civic with a bit cut off and some enlarged-for-Konis stock tophats. I think somehow a chunk of the original bump stops is in there as a spacer or washer. I vaguely remember burning the old rubber off it.
    I've also got a set of old (pre-FCM) mazdaspeed spacers a SM guy gave me that let you use the NB top hats. What, other than the NB top hats, do I need to make these work? Are front and rear top hats the same part? I can get gabriel brand ones off Amazon.com for $40. Good?
    I'm going to replace the '90 springs with the FM ones. Are there other reasonable alternatives out there? Anyone use them with Konis? FM's site specifically warns against konis+fm springs+FM top hats. I'm not interested in lowering the car much. Stiffer is good, losing suspension travel on Michigan roads sucks.
    Thanks!
  • Woody
    June 22, 2011 1:36 p.m. Woody SuperDork
    I currently have a set of new FM springs on almost new Koni's (because I already had them) on my '96. I'll be heading for the track soon for the first time with this car. I know it's not the ideal setup, but I've always had great luck with Koni's. When they fail, I'll replace them with something else.
