I've finally found a good motor to swap into the Nubira. It's a 1.8L DOHC Opel/Aveo/Daewoo style E-tech. This is not the same engine as the Ecotech, and as far as I know they share no parts. I want to take the entire thing apart for educational purposes, so the rods, mains, pistons, head, etc are coming out. I'm just going to buy a Daewoo rebuild kit, so new bearings/gaskets/waterpump/timing belt type stuff.
The ideas I have so far:
Using scales stolen from the science department and a dremel tool to polish and balance the rods.
De-burring the block, again, just a dremel tool.
Porting the intake and exhaust manifolds. Port matching everything. Depending on which intake manifold I get (aluminum or plastic), I might try cutting down the runners and shortening it.
Building a baffling system for the oil tank to prevent starvation. I was thinking I'd just use scrap metal and a welder for this. I was also considering opening up the drainage holes in the cylinder head since the 1.5L version of this engine pushes too much oil up there in racing conditions.
Polish the combustion chambers, unshroud the valves.
Maybe some mild cams. Maybe.
Is there anything else I could do cost effectively? Anything I should look out for? Anything patently stupid in what I'm planning?
