Login to post Forums » Grassroots Motorsports » Midlana heading to dyno Thursday « 1 2 »
  • Taiden
    Sept. 23, 2010 2:49 p.m. Taiden Reader
    275-375 rwhp is my guess assuming a good tune.
    I don't know how low you will set boost, I'm not sure if you are going for longevity or omfgholycraphorsepower.
    275 if you are being conservative with boost 375 if you aren't :D
  • akamcfly
    Sept. 23, 2010 2:58 p.m. akamcfly Reader
    Mikey52_1 wrote:
    Midlana.com has been one of my favorites for a while...I get flak from my SO when I spend too much time there...so much carporn, so little time...
    Me too. Every Monday after work I check for new posts. One of very few blogs I read on a regular basis.
  • Racedreamer
    Sept. 23, 2010 7:23 p.m. Racedreamer New Reader
    Your blog is full of awesome and win! Good luck at the dyno.
  • 4cylndrfury
    Sept. 23, 2010 9:08 p.m. 4cylndrfury SuperDork
    still not done reading the blog. coopers story broke my heart. im so glad you have midi now! for what its worth, my husky bandit sleeps the exact way midi does...feet up, head /neck/back twisted 180 degrees the wrong way...our crazy sons . your site is an inspiration. if you find yourself near cincinnati, youve got a few cold beverages with your name on em!
  • NOHOME
    Sept. 23, 2010 9:54 p.m. NOHOME Reader
    Can we get a drumroll here or something?
  • Taiden
    Sept. 23, 2010 10:12 p.m. Taiden Reader
    brrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrRrR............
  • akamcfly
    Sept. 24, 2010 8:27 a.m. akamcfly Reader
    HP is posted on the blog - I won't spoil it.
  • DILYSI Dave
    Sept. 24, 2010 8:33 a.m. DILYSI Dave SuperDork
    Wow. I'm really surprised that the 91 Octane did that. I'd be very concerned that the knock sensor going crazy was not a false reading, but reality.
  • DaveEstey
    Sept. 24, 2010 9:27 a.m. DaveEstey Reader
    Wow. And people say that Honda engines don't make torque! Look at that plateau!
    I don't see the Vtec crossover point. Am I missing something or is it really that smooth?
  • DILYSI Dave
    Sept. 24, 2010 9:42 a.m. DILYSI Dave SuperDork
    Tuned properly, the VTEC switchover is smooth. Honda intentionally switches it about 500 RPM late so that you can feel it "kick in". But that's a marketing solution, not an engineering one.
  • Sept. 24, 2010 1:36 p.m. kb58 Reader
    Uploading the video now... give me a few minutes to update the Video links.
  • Sept. 24, 2010 1:42 p.m. kb58 Reader
    About the VTEC crossover, yes it's working. In fact, during tuning it was audibly noticable, but as he dialed in the tune he found the exact rpm where it's seamless.
  • Sept. 24, 2010 1:45 p.m. kb58 Reader
    Video is up! Right-click-Save please.
  • DWNSHFT
    Sept. 25, 2010 10:54 a.m. DWNSHFT Reader
    Congratulations on your awesome efforts: design, engineering, and construction. What's the official weight?
    David
  • vazbmw
    Sept. 25, 2010 11:28 a.m. vazbmw Reader
    I must buy the book Sorry if I missed this, but when will it be available?
  • Sept. 25, 2010 12:56 p.m. kb58 Reader
    Won't know the final weight until the paneling is done, but about 1500 lbs.
    The book will be available soon after the car's painted, assembled, and has done at least one trackday event.
  • Sept. 25, 2010 12:58 p.m. kb58 Reader
    They tried running it on 109 race gas to find out exactly that, and it did the very same thing. That appears to indicate it's a bad sensor, bad wiring, or an EMI issue.
  • Sept. 25, 2010 1:03 p.m. kb58 Reader
    For those who don't want to bother going to the blog, peak power was 409 whp, torque is ~ 290 nearly flat from 3000 - 7000 rpm. Boost rises slowly from 6 psi @ 3000, to 9 psi @ 8000.
  • Sept. 25, 2010 1:35 p.m. z31maniac SuperDork
    I need to finish reading the blog so I can see what tire sizes you plan to try to put that much power to the ground with.
    Great job on the build, excellent work as usual.
  • Sept. 25, 2010 1:43 p.m. kb58 Reader
    In reply to z31maniac:
    They're Toyo R1s, 275/40-17, about as large as will fit under the 12" fenders - had to go with that size to validate that they would really fit, at least that's the story I'm sticking with.
  • Sept. 25, 2010 10:02 p.m. Mikey52_1 Reader
    So I guess that means you won't be shifting much then. That is a WIIIDE torque curve.
    But very cool.
  • Sept. 25, 2010 11:15 p.m. kb58 Reader
    The final drive and 1st-4th are low numerically; first is good to 54, and second's good to 85 mph. Granted, it'll still suck at autocross...
« 1 2 »
