Login to post Forums » Grassroots Motorsports » mk4 gti experts needed!
  • DuctTapeEngineer
    Sept. 17, 2009 9:47 a.m. DuctTapeEngineer None
    Hi everyone.
    I'm in the market for an mk4 gti 1.8t. This will be my daily driver that will get autocrossed and see some track days a few times a year. I'm really looking for a 337/20th AE for the brakes and larger rubber but my current car is dying fast and they are hard to find.
    Is the step-up from a base gti to a 337/20th a significant deal breaker (ie: am I going to regret buying a base for every day of my life)? If not, what is the best performing year/option combination mk4 to buy?
    Thanks!
  • Rusty_Rabbit84
    Sept. 17, 2009 9:49 a.m. Rusty_Rabbit84 Dork
    You could always buy the brakes off of a 337 and slap them on the GTi, then come to me for some software to flash on it
  • DuctTapeEngineer
    Sept. 17, 2009 10:53 a.m. DuctTapeEngineer New Reader
    In reply to Rusty_Rabbit84:
    I hear that, but are the master cylinders and the proportioning valve the same? And will the abs be compatible? I had a civic with an si brake swap and ever since then I never bothered with anything besides oem brake systems since they have the most r&d behind them. And the price difference between a base gti and a 337 is about $700. Not even counting the wheels and rubber I'm already in the hole. So it doesn't make much sense to me.
    The only mods I want to do are: hawk pads, short shifter, gt28rs, flywheel, clutch, intercooler, and maybe (big maybe) lsd. So if/when that happens I will be talking to you about software.
  • EricM
    Sept. 17, 2009 10:57 a.m. EricM HalfDork
    I had a 2002 New Beetle Turbo S, I had a second set of wheels with Yokohama tires (AVS) . I did the standard Bilstein Struts/shocks and Nuespeed anti-swaybars.
    Had I kept I would have deffinatly gone with a different intercooler (the on in mine was tiny) and then gotten the ECU flash.
    Then I just drove it. It is fun, but heavy, you may have already knew that.
    I have seen 337s but never drove any so I couldn't compare the two.
  • Rusty_Rabbit84
    Sept. 17, 2009 11:01 a.m. Rusty_Rabbit84 Dork
    Yes, everything is compatible. If its only $700 dollars between a GTi and 337, just go ahead and get the 337. If you are planning to run a GT28RS, you are talking about alot of money to sync that turbo up... Here is a list just to get it working correctly...
    For 1.8T Transverse. Golf/Jetta
    Required:
    Garrett GT28RS with .86 A/R exhaust housing
    High flow exhaust manifold or header for Garrett turbo
    Turbo-back exhaust including downpipe of 2.5"-3.0" diameter
        High flow catalytic convertor or testpipe (cat-delete)
    Front mounted intercooler with capacity for 350+bhp
    MAF housing with 70mm ID (VR6/225TT)
    430cc Genesis injectors at stock 3bar of fuel pressure
    (380cc 225TT or equivalent injectors at 4bar of fuel pressure may be used)
    Recommended:
    Cold Air Intake (from MAF to front of car)
    High performance divertor valve (recirculating, not dump to atmosphere)
    High performance clutch capable of handling 350+lb-ft of torque
  • Travis_K
    Sept. 17, 2009 12:21 p.m. Travis_K HalfDork
    Have you driven one? I havent, but I know someone with a 20ae and he doesnt like it at all. Looks good, but poor hanlding and lots of issues with getting the check engine light to stay off, etc.
  • Rusty_Rabbit84
    Sept. 17, 2009 12:30 p.m. Rusty_Rabbit84 Dork
    that seems to be the running joke with Mk4s, that CELs are constantly on, "Driver found, need handling" types of jokes...
  • DuctTapeEngineer
    Sept. 18, 2009 4:18 p.m. DuctTapeEngineer New Reader
    I am aware of what I need and have done my research on that. ATP has a pretty straight forward kit plus I do have access to a shop and a buddy that is a far better welder than I am to iron out the tiny things. Thanks for the info, though. (http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product...)
    Travis_K wrote: Have you driven one? I havent, but I know someone with a 20ae and he doesnt like it at all. Looks good, but poor hanlding and lots of issues with getting the check engine light to stay off, etc.
    I used to have an 02 mk4 gti about 2 years ago, I liked it (fixed the recurring 2nd o2 sensor cel), changed the timing belt and still liked it enough to keep it around. I wasn't crazy about how the car didn't transition as well as I would've liked it to, but I think that was just me getting used to a car without double wishbones at every corner. I have not driven a 337/20th AE yet so if anyone has, please chime in.
    Thanks again
