It is not 180 degrees out, but it was so badly out that I couldn't see the marks. After much trial and error, it is getting closer.
If I line up the dimples on the toothed wheel on the distributor like I am supposed to, the car will only start if I rotate the distributor clockwise as far as it will go. The car still stutters and stalls and runs like poo, and I can't advance the timing to where it belongs. It is too retarded, and I mean that both ways.
If I remove the bolts that hold the dizzy in, I can rotate it a little bit more and it gets better, so I pulled the dizzy, and turned the toothed wheel back one tooth and reinserted. The car runs much better and starts right up, but the timing is now too advanced. I can't retard it enough
So can I simply give up and run it as is? If the far left line on the pulley is TDC, and the middle is 10-degrees and the third is 16-degrees, I would say that it idles at about 25 degrees when all warmed up. Oil pressure is good, no warning lights, no check engine...
