Posted this on the Volvo forum, but wanted to ask the braintrust here. Since I'm a novice at fixing cars, I obviously made a mistake somewhere and want to figure it out.
I need some help with my '96 850GLT wagon. I replaced the rear pads and rotors on Sunday. This was only the second time I had replaced pads/rotors, the first one was on the car in my avi. When I went to put the left side caliper back on with the new pads, I noticed it was a really tight fit. Obviously, it was too tight. The first mile or two was fine, but then suddenly there was a loud noise coming from the left rear of the car. Hard to describe, you'd have to hear it. I turned right around to head home. It was a definite rubbing sound, but not metal on metal. It was very loud. It was a constant pitch sound, like something dragging. It only seemed to happen above 25-30mph, it would quiet down quite a bit and go away at lower speed as I was heading home. When I got home, I could smell brake pad, and you could feel some heat coming from the left rear wheel. Rotors weren't glowing (it was dark outside) and it wasn't an incredible amount of heat, but noticable. Right side rotor seemed fine, a bit warm to the touch but that's it...no noises, nothing. Pulled the left rear wheel off and you could see the pads pushed up against the rotor. Pulled the caliper back off. I figured maybe I didn't get the caliper fully spread. I put the old pads back in (they still had some meat left...it was the right side that was worn out and caused me to replace everything). It was late at night and I needed to at least get it drivable for the next morning, so I figured I'd go back to what I had (except for the new rotor). The problem is 90% gone now, but I can still hear that noise faintly at higher speeds. When I got to work this morning, the left rear was slightly warm compared to the right.
Did I not get the caliper spread far enough, or did I damage it? What should I be looking for? I used a C clamp to spread the caliper. When I was spreading it, there was a few spots that had significant resistance. I'm confused...
