thatsnowinnebago
thatsnowinnebago GRM+ Memberand Dork
2/27/09 3:59 p.m.
I think your Neon might be cursed.
Carson
Carson Dork
2/27/09 5:02 p.m.
Put some jack stands under there!
Per Schroeder
Per Schroeder PowerDork
2/27/09 5:36 p.m.
The jackstands were sitting right next to me as I took that picture....they were then put under the car.
Per Schroeder
2/27/09 5:59 p.m.
The brakes on our Neon weren't up for much performance use, fading after just a few stops from 60 mph. We decided to replace the rotors with new cross-drilled and slotted pieces from Racing Brake and pads from Carbotech. We chose Carbotech's XP8 autocross pad for our Neon, as it should also work well in a rallycross setting.
Unfortunately, one of the phenolic caliper pistons decided to shatter as we were retracting it into its bore. We've got a new one ordered, and we'll be able to test our new brakes soon.
Carson
Carson Dork
2/28/09 10:19 a.m.
Oh good, safety first, especially for new fathers!
VanFab
VanFab New Reader
2/28/09 6:51 p.m.
Thanks for all of the progress updates, Per! Keep up the good work.
VanFab
VanFab New Reader
2/28/09 6:53 p.m.
P.S. What's that crazy oil filter you're using?
neon4891
neon4891 UltimaDork
3/2/09 9:06 p.m.
Drilled and slotted and all that fancyness? How will those hold up?
iceracer
iceracer PowerDork
3/4/09 9:40 a.m.
A lot of expense for no benefit. OEM type rotors work best.
can
can
3/15/09 9:49 p.m.
I had a bad experience using Carbotech bobcat pads with Racing Brake rotors. Racing brake doesn't recommend using Carbotech pads and Carbotech doesn't recommend using Racing Brake rotors. I experienced poor stopping and overheating. Switched to Hawk pads. The Carbotechs worked great with the OE rotors.
5LzImEfoNDKGlwiL3GpXVEyqtjBxCvj2PbhFqXNUJoObKUdirY4FpOBWHsL0lVFH
