I'm trying to plan out the Celica build a bit better than i did the Escort. That being, i want to have true "stages" to complete before moving on to the next instead of "BUY ALL THE THINGS, TEAR DOWN AND DESTROY TWO CARS, HOPE IT ALL GOES TOGETHER!!"
I'm still working on the motor side of things (and transmission for that matter, ugh), but something else i've been worrying about is the wiring.
I know i can somewhat easily adapt the harness that's in the car right now to run a "Gen2" 3sgte, which is what i have at the moment. There's only 1 PNP EMS at the moment that i know of that would work for this, though, and i REALLY don't like that option. (Hydra)
On top of this, there's a good chance that i'll be ending up with a weird hybrid motor of sorts. (Camry block and crank, "gen3" head and fuel system) This makes converting the existing harness a bit harder.
So why not just make the harness from scratch, and use whatever EMS i want? (Probably AEM because it's so well supported)
Motor will be completely stripped of all unnecessary accessories, so i imagine that would make things easier to deal with.
Anyone done this? Is this too big of an undertaking for someone like me that has very basic knowledge of electrical stuff at best? The plus side is that i do solder pretty well.
My biggest concern is making things worth with the factory connectors at the motor end, but i imagine i could take a try with re-pinning connectors off the Celica harness?
I've modified a few harnesses, what I have found is this: those things are built like E36 M3 under the tape. When I did the Jensenator's harness (Mazda 13B rotary), the number of splices and just plain weird stuff hidden by the tape really surprised me. Like xfactor, I say hang the ECU and other stuff such as the air flow meter where you want them, then run the wires as needed being sure to allow for engine movement, staying away from hot stuff, etc. Solder and shrink wrap anything that will be inside the harness. The 'dry' tape used by the factories is readily available and is a LOT easier to use than the hardware store stuff. Just one place that stocks it:
