Reman master cylinder #2 showed up yesterday. This one was also brand new but it came with new reservoirs and caps! Apparently this one was made with love since I could bench bleed it no problem.
Installed it in the car, bleed everything, and now the brakes finally work like they should.
Since the car now runs, shifts, and stops I decided to insure and register it yesterday. I might have gotten a bit ahead of myself but I can’t really do much more trouble shooting with it just sitting in my driveway. First test drive did go as well as I hoped. I pulled out of my driveway then quickly turned down a less busy side street. Right away I noticed the car does not want to go past 2000 RPMs. It feels like its hitting a rev limiter. I can rev it fine in my driveway but under load I have the issue. Next the fuel pump is very loud. I can’t even hear the engine or any other noises over it. It makes trouble shooting anything else difficult. Last problem is I’m still getting blue smoke out the exhaust. Defiantly much less then before but enough to make people look at me funny. Test drive didn’t last too long and when I got back to my house I pulled the plugs and they all look great. None of them were oil soaked like before.
Now I’m thinking that my exhaust system is full of oil. Before with the bad rings it was enough to have oil pour out the end of the exhaust. What are the chances that when I get on it the oil is still burning out of the exhaust system?
As for the rev limit of 2000 RPMs I cleaned and tested the TPS and connector but that checked out. At some point it looks like someone opened up the AFM since the cover was held on by copper RTV. When I removed the cover everything looked normal. Guess I still have some more testing to do.
