tuna55 wrote:
92CelicaHalfTrac wrote:
tuna55 wrote:
BoneYard_Racing wrote:
Another vote for Chrysler 2.4 here.
other useful things
Hey, that's perfect. Thanks for sciencing that out for me. Now if only I could figure out what Ben's alphabet soup is all about with the Mazda choices I could compare!
I drive a PT Cruiser now. Weird to think of the same (ish) motor making that kind of power.
I'll think about it.
LOL!!!
What needs to be defined? Sorry, i'm really bad about that, i speak fluent engine code stuff.
Megasquirt, HKS PFC Fcon if you can find one, RX7 460s + FMU setup, or 370-390cc injectors on stock ecu with a hacked VAF.
I gathered we are talking about injectors from an RX7 with whatever an "FMU" is. What's a "VAF" and how does one hack it? What's a HKS PFC Fcon?
Basically, what do I need to run the F2T other than the engine? Also, what do the H type transmissions you spoke about show up in?
Oh my bad. "FMU" = "Fuel Management Unit." Basically it's a rising rate fuel regulator of sorts. More boost = more fuel pressure = more fuel.
VAF is "Velocity Air Flow Meter." It's similar to a MAF, used on the F2T. There's a spring in there that you can move to help "tune" crudely for different injectors. You can also make a stopper so it doesn't hit boost cut anymore.
HKS PFC FCon is/was an old piggyback tuning solution, probably the only ever made for this motor. Works quite well, lots of buttons, not the easiest thing to find these days. I have one, it'll be on the car for the challenge, within challenge budget, but it took some searching.
The H-Type transmission is the 5-speed found attached to any F2T. Wasn't used with any other motor. Mazda developed that transmission because the normal "G-series" transmission that was on the non-turbo cars just couldn't handle the F2T. They got shredded pretty quick.
If you're going megasquirt and like wiring, just make your own harness, otherwise, you'll want all the accessories, harness, trans, and ecu.
