I have been searching the web on this subject for a while but keep coming up short on answers.
My question is: For a rear wing, Is there an optimal height above and position relative to the rear edge of the roof of a hatchback?
It seems most racing body rules dictate wings cannot be above the roof line (or severely limit how far above the roof they may be), which I assume is why most rear wings on hatches I see in racing pictures are mounted at the roof level and trailing the rear edge.
The rules for the racing I do has no such limit so I want to position the wing I am adding to balance the front splitter optimally.
From what I have read about air flow, the boundary layer of air over a flat surface is under an inch, and given the fact that my A2 Golf roof is not flat but only has a slight downward taper to the rear before the edge, I would think that a wing greater a 3-4 inches above the roof would be in pretty undisturbed air.
I also read that positioning the wing so its front edge is about in line with the roof rear edge may be optimal, both to increase leverage on the rear wheels and to help with drag. I understand the first part but not the second.
Anyone with experience care to share on this?
Thanks.
