I recently acquired a Volvo 960 that had the upper cylinder head off for quite awhile. The buckets are pitted, so I'm going to snag some "new" ones from PnP and possibly get the earlier cam (+20hp peak but an unquantative less amount "under the curve) but I'm not positive.
I have new valve stem seals, but I'd like to get the valves nice and clean. None are damaged.
Is it imperative to keep them in the same order as they came out? I'd like to drop them in some Chem-Dip, but they would likely get mixed up.
Also, when I get new buckets/HLAs, I'm assuming it would be bad to drop them into the Chem-dip, I should probably just pump them in some clean oil, right?
