I'm pinching pennies real hard since I'm out of work and I'm considering reusing a wheel stud that was pressed out in the past to replace this one that broke. This issue has been discussed very little online, I saw one mechanic recommend against reusing studs, while another said it was fine once the stud is in good condition, but that guy also recommended the hammer out+pull in method of stud changing rather than using a press so...
What do you guys think?
I've done it in the past, with no ill effects, but I'll spring for new ones time and finances permitting.
Suprf1y
UltimaDork
10/8/19 8:13 a.m.
Every time you change your wheel you are reusing a stud.
Either the knurl holds or it doesn't, and there's nothing wrong with the hammer/pull method if you're not a butcher.
Thanks guys, I'd be willing to try reusing a stud now, but it looks like this thread is going to end in a somewhat disappointing way: I got a good deal on some extended studs from one of the high-end race shops here, they each cost just a little more than a Land Cruiser stud from the dealership. They're a bit longer but also have a bit more shoulder, but I think my days of using steelie spares on this car are coming to an end anyway. Here you can see one with a Land Cruiser stud on the left and a Corolla stud on the right:
Don't know what brand they are but they were brought in for use on a race car, they have an "E" stamped into the head.
