Appleseed wrote:
I think it comes from improper bedding. Slapping on new rotors and pads and driving like normal. The pads will heat up and transfer some of the friction material to the fresh rotor. Then you go into Wal-Mart. The pad still is transferring material to the disk, just in that one spot. That spot is now extra "sticky." When you come out of the store and drive, then brake, its sliiiiiide-grab-sliiiiide-grab-sliiiide pulsations.
Stop Tech's web site has a great section on brake bedding. I use cheap crap Vato-Zone's on the Caprice, and using their procedure worked awesome.
Not sure if there is a free fix. Maybe pull the pads, hose down the rotors with brake cleaner, and scuff both sides with steel wool?
I try to bed in the pads per as best I can, but I live in a city (fairly high traffic area at that) so it's a bit tricky. I suppose I could do it at 3am next time around...
I'll have to check out the Stop Tech site. Though I am somewhat happy to hear that it might not be warped rotors - I'm running half-way decent stuff, NAPA blanks with their mid-level ceramic pads (PBR), so I was rather grumpy when they started acting warped a few months ago.
