Login to post Forums » Grassroots Motorsports » Rusty Nuts?
  • pinchvalve
    Jan. 6, 2009 9:10 a.m. pinchvalve UltraDork
    Loctite Freeze and Release
    I look forward to the first unbiased review on this board.
  • confuZion3
    Jan. 6, 2009 9:17 a.m. confuZion3 Dork
    I haven't looked at the product yet, but judging by your title, this sounds like something you'd want to talk to your doctor about first.
  • foxtrapper
    Jan. 6, 2009 9:22 a.m. foxtrapper SuperDork
    Shrinking your nuts for a tighter fit isn't usually the way to get unscrewed.
    But if a cold touch to your nuts really gets them off, save yourself some money and get a CO2 fire extinguisher.
    If this really worked, we'd have been doing it in the Navy. Heck since we recharged our own fire extingishers, we used them for everything, and this wasn't an application we used them for.
  • hotrodlarry
    Jan. 6, 2009 9:29 a.m. hotrodlarry New Reader
    I use this stuff....
    http://www.crcindustries.com/auto/content/fzo.aspx
  • BBsGarage
    Jan. 6, 2009 9:38 a.m. BBsGarage HalfDork
    Did anyone else think this was about the RustyNutz character from the old AutoX days?
  • Tyler H
    Jan. 6, 2009 9:57 a.m. Tyler H Dork
    I'm a PB Blaster man. I also use a 3lb drilling hammer with a cut-down handle. If a combination of those two doesn't get it done, then something is going to break.
  • pinchvalve
    Jan. 6, 2009 10:24 a.m. pinchvalve UltraDork
    Good to know about the CRC product, I try to support GRM advertisers whenever I can!!!
  • Salanis
    Jan. 6, 2009 10:53 a.m. Salanis SuperDork
    [Giggle]
    I feel way too juvenile right now.
  • GameboyRMH
    Jan. 6, 2009 11:46 a.m. GameboyRMH SuperDork
    Epic post!!!
    Also I've tried cooling nuts with CO2 spray...it's never helped.
  • pkrstr8
    Jan. 6, 2009 1:08 p.m. pkrstr8 New Reader
    Actually C02 spray and a hammer is a great way to remove a nut. Just not of much use after.
    This post is just too easy!!!
  • tjthom
    Jan. 6, 2009 1:15 p.m. tjthom New Reader
    Not tried the fun of CO2... yet... But so far KROIL has done the job for me everytime.
    http://www.kanolabs.com/
  • SkinnyG
    Jan. 6, 2009 8:47 p.m. SkinnyG New Reader
    The best thing is to avoid the rusty nuts entirely with a preventative measure such as dryer balls:
  • 44Dwarf
    Jan. 8, 2009 12:22 p.m. 44Dwarf Reader
    try Olive oil.....worked for Popeye.....
  • m4ff3w
    Jan. 8, 2009 4:07 p.m. m4ff3w Dork
    The Loctite stuff looks just like the CRC stuff.
    I tried the CRC stuff and was not impressed at all.
  • motomoron
    Jan. 10, 2009 3:24 p.m. motomoron New Reader
    Heat wrench followed by Kroil followed by more heat wrench followed by huge hammer and specially made punches followed by kroil followed by heat wrench...
  • Kendall_Jones
    Jan. 10, 2009 3:42 p.m. Kendall_Jones New Reader
    Hardcore Kroil believer / user here (Michigan = Rust). One of the keys to Kroil effectiveness is allowing it to soak in. Spray it down a day or so ahead of time with repeated applications. I've had more luck with Kroil than PB blaster (although PB works in a pinch).
    If your short on time, Mr motomorons post above will work without fail (heat & quench).
    Kendall
  • NOHOME
    Jan. 10, 2009 4:56 p.m. NOHOME New Reader
    I am cheap (Grassroots?) and find that diesel fuel works as good as anything else on the market. Sure does stink though!
    Pete
  • gamby
    Jan. 10, 2009 5:46 p.m. gamby UberDork
    "I hardly even know 'er!!!"
  • Daddy_Rocket
    Jan. 11, 2009 6:31 a.m. Daddy_Rocket New Reader
    Well, it'll work. It'll work best in conjunction with a heat/freeze cycle, though. But really, all you need is a torch. Heat does amazing things to metal that's rusted together...
    And if it doesn't loosen up, you can just go higher and melt the sucker off. That's my favorite.
