Login to post Forums » Grassroots Motorsports » RX5.0 project « 1 2 3 »
  • aussiesmg
    Jan. 29, 2012 7:29 p.m. aussiesmg SuperDork
    The front end is done with custom coilovers, Respeed hollow front sway bar custom made to fit the 5.0, Koni inserts, Eibach springs, steering spacers, camber/caster adjusters and more.
    The rear end is next, going to rebuild the upper control arms to be equal length to the lowers, box the floor and build a panhard to replace the flawed watts linkage. Haven't decided if I will do rear coilovers as they also require full custom mounts to be built. I will se how it handles and balances out on scales first.
    Got the hood installed and cut to fit around the intake today.
  • aussiesmg
    Jan. 30, 2012 10:41 a.m. aussiesmg SuperDork
    Here is the dyno reading still on the computer.
    Photobucket
    The beast on the ramps
    Photobucket
    A few pulls and a little fun
    Here is yesterday's efforts, first some trimming
    Photobucket
    Check fit
    Photobucket
    It works
    Photobucket
    Topped off
    Photobucket
  • aussiesmg
    Jan. 31, 2012 5:58 p.m. aussiesmg SuperDork
    http://s869.photobucket.com/albums/ab256/aussiesmg/RX50/?action=view&current=M...
  • Karl La Follette
    Jan. 31, 2012 6:33 p.m. Karl La Follette Dork
    Awesome effort ! Car looks sweet . Expecting a driveability report soon . Interior piks ?
  • pres589
    Jan. 31, 2012 6:43 p.m. pres589 Dork
    What mufflers are you using?
  • aussiesmg
    Jan. 31, 2012 6:46 p.m. aussiesmg SuperDork
    These ones
    Photobucket
    http://grassrootsmotorsports.com/reader-rides/835/
    More on the build
    http://www.cardomain.com/ride/2845451/1984-mazda-rx-7
  • Canute
    Feb. 2, 2012 12:33 a.m. Canute Reader
    I have an FC in progress. Except the Bill Mitchell aluminum blocks came down to $4,000, so I did that. They are beautiful and stout and look almost nothing like a 302 block except that there's eight big holes and a distributor hole in the front, so it's a lot more than a 302 cast in aluminum. The scale said 98 pounds. I'm going carbed as it's race/track only. I think this puts the long block at 250, maybe 260. Edelbrock Performer heads weigh 40# complete each with roller rockers, girdles, also including lifters and pushrods.
  • Canute
    Feb. 10, 2012 5:21 p.m. Canute Reader
    For those obsessed with the "how much does it weigh?" question, I just had my mechanic lift a fully dressed 5.0 Explorer engine with flex plate. He said it came out to 516 pounds.
  • aussiesmg
    Feb. 11, 2012 11:12 a.m. aussiesmg SuperDork
  • DoctorBlade
    Feb. 11, 2012 11:22 a.m. DoctorBlade Dork
    Sounds nice so far.
  • aussiesmg
    Feb. 20, 2012 3:41 p.m. aussiesmg SuperDork
    Well I do need a transmission, this T5 leaks, whines and has no 5th gear, I might have to go with a built unit to replace this lame duck.
    G-force or Keisler? Opinions welcome with reasoning. I do want a tall overdrive for highway use/
  • cwh
    Feb. 20, 2012 4:19 p.m. cwh SuperDork
    I have a thing for Tex Racing products. Yeah, a bit pricy, but they do hold up well. Just a random thought. Dropped off a tranny there for freshening when I was doing the IMSA thing. I dare you to find Ether NC.
  • Strike_Zero
    Feb. 20, 2012 4:41 p.m. Strike_Zero Dork
    Awesome information!!
  • 1988RedT2
    Feb. 20, 2012 4:50 p.m. 1988RedT2 SuperDork
    Please take that thing down the dragstrip and report 1/4-mile time!
  • aussiesmg
    Feb. 20, 2012 6:09 p.m. aussiesmg SuperDork
    You can remove at least 100lbs from that in this case, with the Trick Flow aluminum heads, roller rockers, lightened flywheel, hi torque starter, etc.
  • Strike_Zero
    Feb. 21, 2012 12:37 a.m. Strike_Zero Dork
    I have the lightened flywheel (12lbs). I'm going to rock the GT40Ps that came with it for now. I could get back to finishing the installation only if the heater core magically jumps into the Dakota and replaces the leaky one; and this rebuilt M42 jumps into the 318is without work on my part
  • Moving_Target
    Feb. 21, 2012 7:05 a.m. Moving_Target New Reader
    The lightened flywheel is something I need to consider as a later upgrade for my build.
    I still haven't heard back from the machine shop on the status of my 5.0.
  • aussiesmg
    Feb. 27, 2012 5:48 p.m. aussiesmg SuperDork
    Well the T5 in the car is a lame duck, leaks, whines and 5th is a handful of neutral.
    I searched around and found a seemingly good deal and took the plunge on a z-box Tremec T5, never installed for a final cash price of $800,not much more than a stock T5 goes for so it's worth the try. 2.95 1st gear and 0.63 overdrive.
    http://grassrootsmotorsports.com/forum/grm/tremec-t5/46144/page1/
    If this fails a TKO500 will be in the future.
  • Canute
    Feb. 28, 2012 11:10 p.m. Canute Reader
    An aluminum block ($$$$!!!!) will take off another 100. Mine is going to be carbureted, alternator only, with a PowerMaster bracket. I'm dreaming that it's going to be even lighter than the 13B. Aluminum heads, Power Master starter, aluminum flywheel, too. Three hundred, less? Looking forward to getting it back to together.
  • aussiesmg
    April 6, 2012 10:06 p.m. aussiesmg PowerDork
    Picked up the Tremec and it is now installed, I now have a functioning gearbox sans stench and noises.
    Tomorrow it gets new tires.
  • chandlerGTi
    April 7, 2012 7:18 a.m. chandlerGTi HalfDork
    I think you should buy an extra set for the rear, haha.
  • Chris_V
    April 7, 2012 10:20 a.m. Chris_V SuperDork
    So cool. I really miss my 5.0 FC. 2720 lbs with ful interior and Autopower roll cage.330HP
  • aussiesmg
    April 12, 2012 4:40 p.m. aussiesmg PowerDork
    Saturday 10 am
    Photobucket
    Saturday 12 pm
    Photobucket
    Photobucket
    Mohr tires FTW
  • aussiesmg
    April 12, 2012 4:42 p.m. aussiesmg PowerDork
    Kumho Ecsta XS, gained width, gearing and clearance.
    Photobucket
  • Javelin
    April 12, 2012 6:08 p.m. Javelin UltimaDork
    Man those tires make it look soooo much tougher! Awesome!
« 1 2 3 »
