One of our own has offered to make a set for the challenger if I can get the specs, so.
Anybody got a spare or the specs on these plz
Steve
Steve
I can not help you wiht parts or specs on the mustang but if your friend could make up ones that have bolt in ball joints that replace the aluminum A arms in the 944's I bet they could make a little $$$ selling them on the side.
Dean
Aussie if you end up getting these done, I would prob be interested in a set. For some reason I'm having a hard time getting mustang exhaust sounds out of my head, and I tend to lean towards the sn cars.
dean1484 wrote: I can not help you wiht parts or specs on the mustang but if your friend could make up ones that have bolt in ball joints that replace the aluminum A arms in the 944's I bet they could make a little $$$ selling them on the side. Dean
Like the original stamped steel arms do? :)
If your going to make you own then you can really make them as long or short as you want. I made a couple of different sets for my race car. One was a fixed length using stock Fox BJ and poly bushings. The second set used the taller BJ then available and heim joints for the inner mounts. I just used spacers to move the LCA forward or backward on the mounting bolts to set the caster. I could also adjust the heim length to move the BJ forward or backward as well which changes the caster setting as well. You can also change the length of the heims to change camber.
I used 3/4 heims and 5/8 bolts and spacers with shoulders sized to fit the ID of the heim.
I made these on a jig I made using a stock FOX LCAs with the BJ location being moveable. Use .120 DOM tubing of at least 1 inch OD to 1.5 OD for the LCAs. Making the "pocket" for the BJ is the tough thing if you don't have access to someone with a lathe. I happern to own my own and this was not an issue. BJ's do not all have the same OD. Moogs tend to be larger and some are samller then OEM. Don't assume they are all the same size!
In reply to jimbbski:
That is great info.
The adjustable set you built is about what I have in mind, I just want the info for the camber caster changes to set a baseline.
