My daily driver has had solid engine mounts in it for the last 5 years or so. Normal V-8 rear wheel drive metric framed Chevy. The engine mounts are solid with a polyurethane tranny mount. There's all different styles of solid mounts and some are better than others. I have one 1/2" bolt attaching the mount to the frame on each side with the normal 3 bolts attached to the block. I've had the engine shift just once, and only a little bit. It's also a pretty low horsepower engine, but I will run it hard. As much as I hate to go directly against what's been posted, my research told me to have one "soft" spot in the drive line to allow for chassis flex. It probably won't be a big deal at all until the horsepower gets up there, but without a flex point somewhere, that's when things crack, usually something like a bellhousing. I spend quite a bit of time circle track racing street stocks, so if there's a problem, it will show up there, but the frame is also stiffened up with a full roll cage to keep chassis flex to a minimum. My engine mount bolts are grade 8, safety wired in, and I don't nearly have as much trouble out of them as I expected. Depending on how you design the solid mounts and attaching points, you can bolt it in and forget about it. Just don't forget the safety wire. Vibration does become an issue.
