Login to post Forums » Grassroots Motorsports » Somebody please figure out how to put a Subaru engine in one of these...
  • Woody
    June 7, 2010 7:27 a.m. Woody SuperDork
    Bad engined Boxsters are starting to get really cheap. Somebody needs to figure out how to mate a Subaru engine and starter to these transaxles.
    Not mine, etc... http://newyork.craigslist.org/brx/cto/1778875787.html
  • June 7, 2010 7:29 a.m. petegossett SuperDork
    "Triptanic"??? Is that like a sinking ship?
  • 93celicaGT2
    June 7, 2010 7:51 a.m. 93celicaGT2 SuperDork
    I thought the Boxster S had a 2.7 litre?
  • RossD
    June 7, 2010 8:05 a.m. RossD Dork
    Kennedy adaptors?
  • Woody
    June 7, 2010 8:33 a.m. Woody SuperDork
    RossD wrote:
    Kennedy adaptors?
    Nobody makes a workable adapter. The Subaru starter mounts on the transmission, the Porsche starter mounts on the engine
    And, yes, the "S" did not cone with a bigger engine. Something's fishy with this car.
  • Wonkothesane
    June 7, 2010 8:37 a.m. Wonkothesane Reader
    That sounds like it could be a fun project... It's been a while since I had my 2.5l, I'm wondering how much a junked engine sells for to make something up...
  • Otto_Maddox
    June 7, 2010 8:48 a.m. Otto_Maddox Reader
    It looks like you can get a good used engine for around $3K or so, or an S engine for another $1500 on top of that.
  • Wonkothesane
    June 7, 2010 9:14 a.m. Wonkothesane Reader
    I was thinking a junked motor to make a swap on..
    If I could sell a couple of sub frames or whatnot, it might be enough to justify the project.
    Eh, i don't have time for that kinda stuff right now, unfortunately.
  • 914Driver
    June 7, 2010 9:15 a.m. 914Driver SuperDork
    What could be so horrible that can't be rebuilt?
  • John Brown
    June 7, 2010 9:25 a.m. John Brown SuperDork
    Porsches are not rebuilt, they are reborn after being blessed by sweet baby Jesus... Don't ya know?
  • HappyJack
    June 7, 2010 9:32 a.m. HappyJack New Reader
    I don't know enough about Boxsters, other than I love them. Is there an inherent problem with the engines?
  • pinchvalve
    June 7, 2010 9:36 a.m. pinchvalve SuperDork
    Yes, they are expensive.
  • 914Driver
    June 7, 2010 9:42 a.m. 914Driver SuperDork
    I think I like the MR2 better.
  • Wonkothesane
    June 7, 2010 9:54 a.m. Wonkothesane Reader
    There's a couple of problems with the 2.5s, the early (pre-2000s) had slipping cylinder liners due to casting issues, some cracked heads/blocks from the same issues, all of them have leaking rear main seal issues (If it hasn't started leaking by 20k, though, it probably won't!). A big killer is the Intermediate Shaft, too.
    The specific failure determines whether it's rebuildable or not.
  • RossD
    June 7, 2010 9:59 a.m. RossD Dork
    pinchvalve wrote:
    Yes, they have Porsche written all over them.
    Fixed
  • mad_machine
    June 7, 2010 11:09 a.m. mad_machine SuperDork
    seems that for the cost of the suby engine and the adaptor and all the heartache.. you can drop in a good Porsche engine that fits the first time and runs when you turn the key.
    Early boxsters (except for their headlights) are tempting
  • Appleseed
    June 7, 2010 10:01 p.m. Appleseed SuperDork
  • EvanB
    June 7, 2010 10:20 p.m. EvanB Dork
    This makes them a bit better looking
  • DirtyBird222
    June 7, 2010 10:28 p.m. DirtyBird222 Dork
    why not and LS1 instead?
  • EvanB
    June 7, 2010 10:31 p.m. EvanB Dork
    Flat-4 would probably fit easier than a LS1, although either would be awesome.
  • June 9, 2010 10:03 a.m. LJD
    I've been hoping someone could make the LS1-boxster swap work, but the LS block is just a little too long and would require relocating the transaxle rearward and some very clever accessory setups. There's a thread covering this in LS1tech's conversion section: http://www.ls1tech.com/forums/conversions-hybrids/1049878-boxster-ls1-swap-ideas-n...
    Also in LS1tech's conversion section is a thread where a guy is making good progress with a C4 996 LS1 swap. Early 996's are also getting very cheap. He did have to cut part of the rear frame/brace and will need to weld some reinforcement where he cut. But the swap looks reasonable for anyone with some fabrication skills because the early 996 wiring isn't too complicated. The later 996's is another story. http://www.ls1tech.com/forums/conversions-hybrids/1240791-2001-porsche-996-ls1-con...
