Knurled
Knurled GRM+ Memberand Dork
3/19/12 9:58 p.m.
IIRC, the engine in the 2002 does.
http://www.ebay.com/itm/bmw-thermostat-2002-e21-320i-behr-/110841914385?hash=item19ceb16411&item=110841914385&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Trans_Maro
Trans_Maro SuperDork
3/19/12 10:02 p.m.
Circle track guys have a lot of cool parts:
http://www.speedwaymotors.com/Remote-Thermostat-Housing,1295.html
Probably uses a cheap Chevy waterneck.
You'll spend more than $70.00 in your time making one.
Shawn
3/19/12 10:20 p.m.
the BMW M42/44 does NOT have a standalone thermostat. I think the M20 might.
The fiat 124 does
44Dwarf
44Dwarf Dork
3/20/12 6:43 a.m.
What size hoses? Most thing Italian have that style.
http://www.ebay.com/itm/Thermostat-Housing-Ducati-748-996-998-Monster-ST-/190591633737?pt=Motorcycles_Parts_Accessories&hash=item2c60258949&vxp=mtr
Buy new there only $17-$19
Gearheadotaku
Gearheadotaku GRM+ Memberand SuperDork
3/21/12 7:13 a.m.
Land Rover Discovery Series II (2000-2004). Part number PEM100990K. About 20 bucks. Housing and stat all in one.
02Pilot
02Pilot Reader
3/21/12 7:22 a.m.
BMW M10 is readily available in 71, 75, and 80degC versions for under $20 each: Linky
mrwillie
mrwillie HalfDork
3/21/12 12:24 p.m.
Pardon my ignorance, but how does a remote thermostat help the car? I don't think I understand............
Will
Will Dork
3/21/12 5:04 p.m.
Ford 4.6 DOHC. 96-04 Cobra, 93-98 Mk VIII, etc.
3/21/12 7:02 p.m.
I know the one in the fiat 124 always allows water to flow. When closed, it simply recirculates the water out of the head back to the pump.. I assume this alleviates hotspots in the engine as it warms up?
novaderrik
novaderrik SuperDork
3/21/12 7:12 p.m.
mrwillie wrote: Pardon my ignorance, but how does a remote thermostat help the car? I don't think I understand............
i think it's more of a packaging thing than anything.. personally, i'd prefer to have the thermostat mounted on the engine so that it reacts more quickly to the engine temp than it would if it was mounted away from the engine.
Raze
Raze SuperDork
3/22/12 6:24 a.m.
mad_machine wrote: I know the one in the fiat 124 always allows water to flow. When closed, it simply recirculates the water out of the head back to the pump.. I assume this alleviates hotspots in the engine as it warms up?
Right on, that's why Fiat went from t-stat in the head where the water pump just churned water that wouldn't move to an external 3-leg design. They're nice, aluminum housing, and big, and around $50...
3/22/12 8:03 a.m.
iadr wrote: In reply to mrwillie: What I am building is a street conversion of a 4cyl Mercruiser marine engine. It was originally only in marine applications, and featured a very "unique" cooling system. The thermostat was located in the intake manifold (which I am not using)... and wait for it, controlled water flow through the cooling shell of the exhaust manifold...and through the voltage regulator. It was the most bizarre cooling system I've seen in 25 years of messing with cars.
yes.. marine engines are odd that way. But if you think about it.. in a marine engine you are fighting not only overheating, but overcooling. By running the cold water (face it.. most lakes and oceans never get into the 90s) through an exhaust manifold jacket, you warm it up to what would be approximatly the correct temp to boil.. and then run it through the engine to keep the moving parts from getting above that temp..
This has the side effect of cooling the exhaust so you do not get too much heat underdeck
RossD
RossD UltraDork
3/22/12 8:09 a.m.
Boat engine? Weird. Yesterday, I just found out that they used the 2.3 Lima engine for boats (OMC Cobra 2.3) and got crazy ideas of a MS'ed turbocharged SVT Zetec in a boat...
3/22/12 8:53 a.m.
yup.. they did. Friend of mine had a small 20 foot boat with the 2.3 hooked up to an OMC outdrive. Was not a fast boat, but very fun and reliable
Knurled
3/22/12 11:59 a.m.
Is this the 3.7l "half a 460" engine?
If so, MORE DETAILS PLZ.
mrwillie
mrwillie HalfDork
3/22/12 12:20 p.m.
In reply to iadr:
Ummm....yep. That's a new one for me, too. Does the voltage regulator get hot enough to require water to cool it? I always thought that an outboard would be interesting in the right car. I've seen people trashing boats and motors on CL just b/c of a bad hull.
Good luck w/ the project!!!
44Dwarf
44Dwarf Dork
3/22/12 12:24 p.m.
Boat volt regs do get hot. Everything on a boat uses many AMP's of power it not unussual to see 200 amp alts
Raze
Raze SuperDork
3/23/12 6:28 a.m.
iadr wrote: Raze- I'll look for a pic of that Fiat housing, thanks
3/23/12 8:35 a.m.
I love the fiat design.. it is simplicity in itself. When closed, the water in the engine continues to flow through the block and head, leading to an even warming, then as it starts to open, it slowly allows cold water from the radiator to mix in.
Somebody fairly clever came up with that system
Raze
Raze SuperDork
3/23/12 8:45 a.m.
In reply to mad_machine:
Makes you wonder if the Germans helped those Italians...
3/23/12 8:55 a.m.
Not sure.. but I can tell you this.. when the thermostat in my fiat failed.. A screwdriver and a gallon of water got me back on the road.. I just pulled the stat and flipped it around so that in it's stuck closed postiion, it still flowed water through the radiator.
was a VERY cold 50mile trip home as the engine never got warm enough to produce heat.. but at least it was better than a tow
44Dwarf
44Dwarf Dork
3/23/12 12:04 p.m.
Whats the bottom silver unit off of? Model / year part number etc.
Knurled
3/23/12 12:11 p.m.
iadr wrote: In reply to Knurled: yes it is. Have you seen the HAMB thread? What would you like to know.
Any details.
I haven't seen any HAMB thread, that group of people seems like exactly the kind of people I don't like, so I never go there.
Raze
Raze SuperDork
3/23/12 12:31 p.m.
In reply to 44Dwarf:
http://www.vickauto.com/newstore/index.php?main_page=product_info&cPath=5_6_24&products_id=1980
irish44j
irish44j SuperDork
3/23/12 7:45 p.m.
If it hasn't already been mentioned, M10-powered BMWs do (2002s, early 318i), etc.
fUoC5MLeZ8K2zJqX7Ry9zLs8CTVVdHxTqtukC9yM8fWejy7od3b18Ia30frjigyY
