i was pretty fired up last night. i finished the last of the wiring necessary to start the LS swapped 95 impala SS, put in new plugs, oil, plug wires, and battery. there are more odds and ends but nothing that would keep me from testing the engine briefly to verify that everything done up until this point has been correct so i can move forward with all the ancillary crap.
hooked up battery, turn key, CLICK. a nice loud CLICK. no turn of the starter. this is the starter that came with the engine, and went right back on with no shims like it came. the engine spins fine with breaker bar, so i have no worries there. i guess sitting on a shelf for 4 years while i decide what car to put my engine in took its toll on the starter. since i get a good solid CLICK am i to assume the solenoid is good? this is one of those newfangled denso permanent magnet gear reduction deals that costs a fortune, and i would like to repair or rebuild it myself if you guys believe it possible. maybe even take apart, clean and lube whatever needs it, and put back together?
