I was changing the gas tank on the mustang today and the steel lines from the in tank pump snapped off flush with the fitting on the flex line. For those that don't know these are the type of line that required a tool be slid into the end of the flex line fitting to release the tangs so you can slide the flex line off the steel line.
Obviously I will be getting a new fuel pump (it is a while you are there item anyway) but how do I get the stubs of the steel line out of the flex line? Heat is not an answer.. .. . Well it is an answer if I really don't want the car any more
. I have them in PB Blaster at the moment. I was thinking of seeing if I can screw something in to the line and then use that to pull the tube out with the release tool in place. The real issue is that the steel line seems to be welded / rusted to the inside of the flex line.
I guess another option is to replace the lines but that is probably a dealer part with a dealer price.
Anyone got any idea's?
