Login to post Forums » Grassroots Motorsports » Story problem....you remember math class
  • Grtechguy
    Jan. 19, 2009 7:55 p.m. Grtechguy SuperDork
    If I have an engine with the following specs, how many PSI should my guage read? or am I not providing enough information?
    Displacement: 171.00 ccm (10.43 cubic inches)
    Engine type: Single cylinder
    Stroke: 2
    Power: 15.00 HP (10.9 kW)) @ 7500 RPM
    Compression: 6.8:1
    Bore x stroke: 66.0 x 50.0 mm (2.6 x 2.0 inches)
  • RobL
    Jan. 19, 2009 8:02 p.m. RobL New Reader
    If your compression is 6.8:1 - a compression test should read about 100PSI on a 4 stroke. But it's a 2 stroke so I'm not sure.
  • Jan. 19, 2009 9:11 p.m. Nashco SuperDork
    Which gauge?
  • chaparral
    Jan. 19, 2009 9:13 p.m. chaparral New Reader
    6.8:1 is the ratio of the volume of the cylinder when the last port closes to the combustion chamber volume.
    You're looking for at least 14.7 PSI x 6.8, so 100. You should get somewhat higher numbers if it's a reed or rotary valve engine due to crankcase compression.
  • chaparral
    Jan. 19, 2009 9:14 p.m. chaparral New Reader
    What engine is this?
  • Grtechguy
    Jan. 19, 2009 9:15 p.m. Grtechguy SuperDork
    It's a Yamaha 175cc still mounted in the '80 DT175mx
  • Grtechguy
    Jan. 19, 2009 9:16 p.m. Grtechguy SuperDork
    Nashco wrote:
    Which gauge?
    The one I use to get compression readings. reads 0-250psi. screws in the spark plug hole
  • chaparral
    Jan. 19, 2009 9:16 p.m. chaparral New Reader
    100 PSI.
    If you want more, check the crankcase seals and put in some new reeds.
  • RXBeetle
    Jan. 19, 2009 11:04 p.m. RXBeetle New Reader
    dynamic vs static compression ratio is the curve ball here. This may help: http://www.dirtrider.net/forums3/showthread.php?t=152854
