I was wondering if anybody can help me model my suspension, or at least give me some insight into how this will work.
Here's the information I have right now.
Four Wheel Struts
Motion ratio front 1.2
Motion ratio rear 1.15
Bars are mounted to the struts, or they would be if I had any.
Spring rates are 488lb/inch on all four corners.
Virtual Arm Specs:
Front A-arm is 5.5 inches off the ground at the knuckle.
It is 6 inches off the ground at the pickup point at the subframe.
The a-arm is 13.5 inches from the knuckle to the pickup.
The A-arm pickup is 16.25 inches from the center of the vehicle.
This results in a roll center height of 6.6 inches and an inclined slope of .037(x) in y=ax+z Cartesian coordinates.
The rear control arms (there are two for each wheel, they are parallel) are 8.5 inches high at the knuckle and 9.75 inches at the chassis pickup point.
The control arms are 21.5 inches long and mount 5.5 inches from the vehicle center line.
This results in a slope of .055 and a roll center height of 10.02 inches.
Track width front is 68 inches.
Track width rear is 66.5 inches.
Wheelbase is 100.75 inches.
The roof height is 54 inches as measured at the b-pillar.
My observed roll rate is 2.5 degrees at maximum cornering G.
