Fine tuning the suspension today. Adjusting the coilovers so control arms are parallel, going to the alignment rack, etc.
Autox Question: I was reading Per's book again today and I think I have have my rates a little mixed up.
Installed setup is:
450# Front springs - Autotech 28mm Hollow front bar, strut bar 572# Rear springs - No rear bar, shock tower bar Poly bushings throughout, Camber plates w/ -2 degrees front, rear -1 degree shims
I have not weighed the car yet, getting corner weighted this week, gutted interior.
I have a rear bar, should I bring it just in case I need more rear rate? Are my rear rates high enough to run no bar? I got as close to 600# as I could find on a Challenge budget.
Drag question: Will my alignment make ANY different on an 86 Jetta with a stock 1.8 8V motor with a cam/gear, exhaust, no accessories, nitrous? Should I make some marks for say, 0 Degrees, while I'm on the rack? I was intending to run the narrow stock rear wheels and load the rear shocks with bump stops. Should I bother changing things for the drags?
Thank you experts.
