Login to post Forums » Grassroots Motorsports » Tank Treads
  • mtn
    June 22, 2009 9:18 p.m. mtn Dork
    We have a 16 year old Honda snowblower that doesn't blow snow, but the engine is still working like it was brand new. We are going to eventually make a go-cart out of it, but my friend had a great idea: get another engine for the other side, and use tank treads.
    Any ideas on how to make tank treads? Keep in mind a grassroots (cheapass) budget.
  • cxhb
    June 23, 2009 1:14 a.m. cxhb Reader
    seriously? it sounds like youve had too much to drink... or maybe not enough... hmmm....
  • ScottRA21
    June 23, 2009 1:16 a.m. ScottRA21 New Reader
    In reply to mtn:
    Used sno-mobile tracks/treads?
  • foxtrapper
    June 23, 2009 5:28 a.m. foxtrapper SuperDork
    Conveyor belting. You can often times gets rolls of it free at the back of factories. It wears out but is still functional.
  • 914Driver
    June 23, 2009 5:37 a.m. 914Driver SuperDork
    Chain link fence stretched over two rollers = off road?
    Dan
  • RossD
    June 23, 2009 7:44 a.m. RossD Reader
    Dont they make tracks that fit on Bobcats and the like?
  • griffin729
    June 23, 2009 3:16 p.m. griffin729 New Reader
    Yes, they do, but they fit over and around the tires. So, I don't see that working on a go-kart. Ingersoll Rand (Bobcat) and other manufacturers do make some equipment that only comes tracked, but for the idea of a go-kart tank I like the snowmobile suggestion.
  • 44Dwarf
    June 23, 2009 3:41 p.m. 44Dwarf Reader
    look up "Raider twin track" and the resulting injurys then think again..
  • JohnGalt
    June 23, 2009 5:21 p.m. JohnGalt Reader
    Tracks like you are talking about can snatch and munch fingers, hands, and all sorts of bodily parts. If its like i am envisioning it could be more of a hazard than you might want. Maybe if the tracks were completely under the vehicle but i would be a bit nervous about having something like that on either side of me in a go-cart sized vehicle.
  • ww
    June 23, 2009 11:54 p.m. ww SuperDork
    I say go for it. If you're worried about catching something in the tracks, just build fenders over them so they're 50-80% covered.
  • June 24, 2009 9:30 a.m. mistanfo Dork
    If you do this, it so needs to have attached armament
  • 914Driver
    June 24, 2009 9:59 a.m. 914Driver SuperDork
    Ooo, Ooo, me, pick me!
  • Appleseed
    June 24, 2009 10:12 a.m. Appleseed HalfDork
    Actually, Bobcat makes tracked skid-steers from the factory. I'd bet if you looked up a local dealer or outfit that sells replacement tracks, you could get a pair of used up tracks for cheap or free. The drive sprocket is what I'd worried about.
  • Kramer
    June 24, 2009 11:04 a.m. Kramer Reader
    mtn wrote: Any ideas on how to make tank treads? Keep in mind a grassroots (cheapass) budget.
    Get a sawzall with a metal-cutting blade, some Dawn dish soap, and some old tires. Cut away! Bolt the ends together.
    But seriously, treads are used to prevent ground compaction, a real problem to farmers, and to distribute the heavy weight of the vehicle over a larger surface. They don't really offer better traction, and speed is compromised.
  • ManofFewWords
    June 24, 2009 1:37 p.m. ManofFewWords Reader
    I operate a tracked skid steer daily, and I can assure you that they do offer better traction, and a better ride as well.
  • YaNi
    June 24, 2009 1:47 p.m. YaNi Reader
    Kramer wrote: But seriously, treads are used to prevent ground compaction, a real problem to farmers, and to distribute the heavy weight of the vehicle over a larger surface. They don't really offer better traction, and speed is compromised.
    They definately offer more traction on wet or loose surfaces. It's the main reason the military uses them. Wheeled vehicles for roads, tracks for cross-country.
    You will never be able to obtain the same size contact patch from a wheel as a track. To do so would require multi-wheel drive and large tires, which would increase the size of the platform.
  • ClemSparks
    June 24, 2009 2:06 p.m. ClemSparks SuperDork
    I highly doubt this. I looked at prices for rubber tracks for a mini excavator some time back (a smaller track) and they were very expensive. I imagine there are no "used" tracks out there for sale (practically speaking) because new ones are expensive enough that they run them 'til they break and then replace them as needed. I could be wrong though. It's happened a few times (or so my ex tells me).
    Clem
  • ignorant
    June 24, 2009 2:34 p.m. ignorant SuperDork
    http://www.mytractorforum.com/showthread.php?t=78449&highlight=homemade+tracks
    http://groups.yahoo.com/group/tracklayinggardentractors/
    done.
  • GameboyRMH
    June 25, 2009 9:38 a.m. GameboyRMH SuperDork
    You know with four of those tracks you could build a Halo-style tank...
    http://media.photobucket.com/image/halo%20scorpion%20tank/quag_04/scorpion1_big.png
  • RossD
    June 25, 2009 9:47 a.m. RossD Reader
    you mean like what this company makes. I think they installed a similar setup back in the day on Trucks on TNN.
  • mtn
    June 25, 2009 1:52 p.m. mtn Dork
    Thats exactly what we're looking for, the treads from the thing on the far right. But a grassroots or homemade version of it
