Login to post Forums » Grassroots Motorsports » Tech II alternatives
  • Grtechguy
    Nov. 18, 2009 2:39 p.m. Grtechguy SuperDork
    Ok....it's seeming necessary to have a live scanner in the garage with newer vehicles.
    has anyone done the ebay cable and opensource software?
    http://cgi.ebay.com/ebaymotors/USB-Auto-Scanner-Interface-OBD-II-OBD2-EOBD-CAN-BUS...
    http://www.scantool.net/
    http://www.obd-2.com/#download
  • Nov. 18, 2009 2:46 p.m. Nashco SuperDork
    It's no Tech II, but I got a Snap-On Brick (aka MT2500) at a yard sale for cheap. I've been tempted to do the laptop method, but the cheaper/free software I've seen has VERY limited amounts of information available. The laptop + software is definitely the way to go, the obvious limitation is the software. The brick is kind of nice because I got a couple of troubleshooting chips with it so that when I get a code P0135, the brick tells me what other codes might be related, the sensor pinout, what readings should be between each pin+ground, power, etc. If the reasonably priced software would do that, I'd be all over it, but so far the only software I've seen gives data and codes, but no troubleshooting info...forcing you to go look for data somewhere else, thus wasting time.
    Bryce
